7911 localisation to English
I have a 7911 IP Phone which is in Korean language. I want to change the language to english. My current CME system localisation is in default english. How can i change this phone text to english???
All my other IP phones are displaying in english.Only this is giving the problem.
I tried adding command user-locale US and network-locale US in telephony-service but still doesnt work.
do i need to add a EN language pack??? Pls advice.
Manoj
You are welcome. Please rate useful posts with the scrollbox below!
5 Replies 5
hadbou
Level 5
Level 5
We also have to post the localisation download files for these phones to a CCO download page. Unlike the 7960/7912, the localisation dictionaries are not built in to the CME IOS image. These files just need to be loaded into the router's flash, with the appropriate tftp-server commands.
I have tried putting the English language pack also. Still it showing half in english and half menus in korean.
Pls assist.. urgent.
Manoj
try a factory reset. Remove power. Reapply while pressing #. Release # when LED flashed in pattern. Press sequence: 123456789*0#
Phone will completely reset and reflash.
Note you need need to have term11.default.loads, and all the associated firmware files on the CME router, and the "tftp-server" commands for all of them.
I did a factory reset and it works.
Thanks a lot!!!
Manoj
