VLAN Setting 7902
Nov 30th, 2007
can anybody help.
i need to configure static vlan on a 7902 ip phone. i want to set it to vlan 2.
I am confused on the hexadecimal setting.
thanks,
kumar.vijayarajan_2 Fri, 11/30/2007 - 04:23
You can set the Vlan to 2 by using the IVR option 324.
1.Lift the handset, then press and hold the Menu button for about 3 seconds.
2.The IVR system plays the following prompts:
• Press 1 # to configure IP
• Press 2 # to configure route
• Press 10 # to configure subnet mask
• Press 20 # to configure DHCP
• Press # to go to the extended menu
3. Enter the 324* voice menu code for the Vlan setting that you want to change and
press #.
4. Then Press 2 for the Vlan number.
4. Enter 3 to save the configuration.
5. Hang up the phone.
The phone resets.
Have you tried this option?
Kumar.v
