WAN Link error
Nov 30th, 2007
we have the following coming up on the router. Please what does this all mean and what next should I do?
Nov 30 02:34:26 GMT: %CONTROLLER-5-UPDOWN: Controller x.x, changed state to down (RAI detected)
Nov 30 02:34:28 GMT: %LINK-5-CHANGED: Interface Serialx.x, changed state to reset
Nov 30 02:34:28 GMT: %BGP-5-ADJCHANGE: neighbor x.x.x.x Down Interface flap
Nov 30 02:34:28 GMT: %CONTROLLER-5-UPDOWN: Controller x.x, changed state to up
Nov 30 02:34:29 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serialx.x changed state to down
Nov 30 02:34:30 GMT: %LINK-3-UPDOWN: Interface Serialx.x, changed state to up
Nov 30 02:34:32 GMT: %CONTROLLER-5-UPDOWN: Controller x.x changed state to down (AIS detected)
Nov 30 02:34:34 GMT: %LINK-5-CHANGED: Interface Serialx.x, changed state to reset
smothuku Fri, 11/30/2007 - 05:08
Hi ,
I think controller on the router has some problem...
Channelised E1 has some problem . I mean it is not constant and fluctuating a lot...
Check with your service provider and if possible take the loop tests...
"sh controller e1 XXX " output can help us in resolving your issue.
satish
qwertys21 Fri, 11/30/2007 - 05:17
Thanks.
I have done a show controller. What should I be looking for, what should it be telling me?
CSCO10758684 Fri, 11/30/2007 - 20:00
hai,
I suspect the issue is there in Link ......alarm indicates (AIS --alarm indication singnal ..and RAI Remote alarms )
Pls check with ;your service provider
(AIS detected)
(RAI detected)
