L3 Routing
Nov 30th, 2007
Follows the instruction to implement L3 routing below:
However, the part where I have to alter one switch port to a routed port is causing problems. As soon as I do that I cannot access the network connected to the router.
However if I connect the router to the switch on a dot1q trunk port, then everything works fine.
I have configured VLAN1 with an ip address and issued ip route commands to the Router.
Can someone clarify?
Overall Rating: 5 (1 ratings)
glen.grant Fri, 11/30/2007 - 05:55
If you are using the vlan 1 SVI for the ip address then your connecting port would be a switchport not a routed port . If you want to use the actual port as a routed port then get rid of the int vlan 1 ip address and put that on the routed port (no switchport) that you configure .
