How to configure management int on Cat6509 with IOS
Nov 30th, 2007
I have a layer 2 Cat6509 Access switch with IOS.
The following is configured for the management interface:
interface Vlan2020
description Network Management Interface
ip address 30.176.20.5 255.255.255.0
ip default-gateway 30.176.20.1
The default GW is on the Cores.
The problem is I can't ping that IP from anywhere on my network and vice-versa.
Overall Rating: 4.5 (2 ratings)
yassine-m Fri, 11/30/2007 - 07:01
Could you send a traceroute to the management IP address. you should check the routing.
glen.grant Fri, 11/30/2007 - 07:14
  • Purple, 4500 points or more
Make sure ip routing is turned off , otherwise you need to configure a default static route instead of a default gateway statement which is only used when routing is actually turned off "no ip routing" .
gkushnir21 Fri, 11/30/2007 - 08:11
I guess ip routing is turned on by default in these switches.
Do I turn it off in global config?
Switch(config)#no ip routing ?
% Unrecognized command
Thank you
Jon Marshall Fri, 11/30/2007 - 08:37
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
You cannot turn off IP routing on the 6500 with IOS release 12.1(20)E and later.
Assuming you have a later IOS the simplest thing to is change
to
ip route 0.0.0.0 0.0.0.0 30.176.20.1
Jon
