Cisco PIX VPN site-to-site same Public Subnet
Nov 30th, 2007
I am trying to create a VPN between a Cisco Pix and a Checkpoint firewall both in the same external subnet:-
PIX Outside 172.20.30.1/25
Checkpoint Outside 172.20.30.2/25
This fails with:-
crypto_isakmp_process_block:src:172.20.30.1, dest:172.20.30.2 spt:500 dpt:500
ISAKMP: phase 2 packet is a duplicate of a previous packet
I guess this is possible to do, as I am wanting to encrypt traffic from 2 directly connected customers as to protect both Environments.
Any help would be much appreciated.
Kind Regards
Steven
Collin Clark Fri, 11/30/2007 - 06:54
  • Purple, 4500 points or more
If you do a search on Cisco for "checkpoint VPN" you will get some hits. Also make sure the firewall has sysopt permit ipsec.
sadcock123 Fri, 11/30/2007 - 07:00
Thank you for the info.
My main questions is should the VPN work with both public interfaces in the same subnet?
Cheers
Steven
Collin Clark Fri, 11/30/2007 - 07:03
Sorry, yes you should be able to do that.
sadcock123 Fri, 11/30/2007 - 08:52
Thank you I have managed to sort the Phase 2 issue:-
crypto map rtprules 10 set security-association lifetime seconds 3600 kilobytes 4608000
Fixed the problem.
Kind Regards
Steven
