core and switch both have different IPs in cdp neigh for the same switch
Nov 30th, 2007
not quite sure why, but the core thinks a certain switch is x.x.x.103 when it is actually x.x.x.2. They both show the same phyical connections so i know its definately the same switch. Only issues I can think of is the two uplinks to the switch are etherchanneled. I ping the address the core has and nothing. Not sure how the core gets the ips, whether its just a table that needs to be reset or something. Thanks
Edison Ortiz Sun, 12/02/2007 - 15:56
Verify the switch holding IP address x.x.x.103 does not have any interface holding such IP
with a show ip interface brief | ex una command.
aemberson Tue, 12/04/2007 - 01:23
sorry, nothing on either our core switch or the x.x.x.2 switch when using the command that points to x.x.x.103
Edison Ortiz Tue, 12/04/2007 - 09:48
Please post show cdp neigh from the switch seeing the incorrect CDP information and show ip interface brief | ex una from the switch sending the CDP.
