WIC-1AM Limitations For Remote Out of Band Support
Answered Question
Nov 30th, 2007
I have the modem working for out of band support in most areas. However, 1 area remains a problem and I am not sure it can be solved.
I know when the router goes into RMON mode access is only available via the console port. If you have an external modem connected (to the console port) you can dial into the router and work.
Since the WIC-1AM is an internal modem (acts like connecting to AUX port) I believe the config must be read b4 the modem is usable. Of course, the config is not read when the router boots in RMON mode. To me this explains why the modem will not answer the incoming call when in RMON mode.
Along that same line, you don't seem to be able "watch console messages" as the router is booting. Where an external modem you can. Is there any way to accomplish that as well with the WIC-1AM.
This is the only drawback I see in using the internal modem vs an external one.
Is there a WIC-1AM firmware upgrade or other way to make the modem answer if the router boots into RMON mode? Is there a way, using the WIC-1AM to monitor console messages when booting before the config is read?
Doug Hogue
Correct Answer by Paolo Bevilacqua about 9 years 3 months ago
Hi Doug,
Your concerns are very valid ones.
Unfortunately, I don' think there is a way now or in the future for the WIC card to replace console or aux during boot process.
Overall Rating: 5 (1 ratings)
Correct Answer
Paolo Bevilacqua Fri, 11/30/2007 - 08:07
  • Hall of Fame,
    Founding Member
Hi Doug,
