3750 rommon xmodem command unknown
Collin Clark Fri, 11/30/2007 - 09:51
  • Purple, 4500 points or more
It's been a while since I had to do that, but don't you invoke XMODEM through the terminal emulator (ie SecureCRT)?
Edison Ortiz Fri, 11/30/2007 - 10:05
  • Hall of Fame,
    Founding Member
The routers using the command xmodem while the switches use the command copy xmodem..
glen.grant Sat, 12/01/2007 - 09:01
I can also advise you to set the baud rate on the switch and the terminal emulator to 115200 , this will take a download of code of this size from like 2 hours down to like 15 minutes .
