Putty plugin for WebVPN
Nov 30th, 2007
I have been playing around with ssl-explorer (http://www.sshtools.com/showSslExplorerCommunity.do) and noticed that they have an ssh plugin based on putty portable. This plugin appears to be a better solution for us than the current Cisco WebVPN ssh plugin since a putty client is downloaded and the user gets to use a standalone application instead of a java window. Does anybody know if it is possible to do something like this with the WebVPN solution
didyap Fri, 12/07/2007 - 13:41
This is currently not possible in WebVPN as WebVPN only supports this via Java. This may be possible in future releases of WebVPN.
