OSPF prefer path
Nov 30th, 2007
My router A is connected to 2 upstream routers,as below,
1-Router A---fa0/0---R1
2-Router A---Fa0/1---R2
All 3 routers running OSPF , I would like Router A to prefer 1st link over 2nd link.
does puting the lower cost on 1st link interface will do the trick ?
bvsnarayana03 Fri, 11/30/2007 - 08:24
OSPF prefers lowest cost path to the destination. So if you have 2 routers & if your preference is to reach R1 than R2, then manually assign cost on interface connecting to R1 some what lower than R2.
Jon Marshall Fri, 11/30/2007 - 08:27
Hi Mohammed
You could either put a lower cost on fa0/0 or a higher cost on fa0/1 or use the bandwidth statement but the bandwidth statement will affect other things such as QOS.
bvsnarayana03 Fri, 11/30/2007 - 10:04
Because it's a fastethernet port, it is advisable not to assign any bandwidth & let it run defaults. You may play with cost to achieve desired results.
royalblues Sun, 12/02/2007 - 11:45
OSPF chooses the outgoing interface cost and hence you would be required to tune the cost value on both the routers.
