send a file from PC to ASA using TFTP server
Nov 30th, 2007
I erased wrongly flash from ASA5520.
I have TFTP server and one ASA OS in my computer .I want to send this file in to ASA but I do not know How?
Have anybody help me?
srue Fri, 11/30/2007 - 10:10
  • Blue, 1500 points or more
from the command line:
copy tftp flash
after that, the prompts will walk you through it.
sedae_1979 Fri, 11/30/2007 - 10:14
I used this way but as you can see it does not function
rommon #14> ping 192.168.3.45
Sending 20, 100-byte ICMP Echoes to 192.168.3.45, timeout is 4 seconds:
Success rate is 100 percent (20/20)
rommon #15> tftp
ROMMON Variable Settings:
ADDRESS=192.168.3.253
SERVER=192.168.3.45
GATEWAY=192.168.3.254
PORT=GigabitEthernet0/0
VLAN=untagged
IMAGE=asa723-k8.bin
CONFIG=
LINKTIMEOUT=20
PKTTIMEOUT=4
RETRY=20
tftp [email protected] via 192.168.3.254
TFTP failure: Packet verify failed after 20 retries
rommon #0>
srue Fri, 11/30/2007 - 10:21
oh, i didn't know you were in ROMMON mode.
and you tftp server is definitely running? does the tftp server show any errors?
the file, asa723-k8.bin should be inthe root directory of the tftp server also.
sedae_1979 Fri, 11/30/2007 - 10:36
I am using Solarwinds TFTP server
Tftp does not show error. It is written only < TFTP Server Service Started [UDP -69 ] >
I am log on in ASA device using console cable. I make ping my computer from ASA device but it is not the same when I try making ping Devices from my computer
I can not make ping the 192.168.3.253 device
husycisco Fri, 11/30/2007 - 11:42
  • Gold, 750 points or more
Make sure either udp port 69 is entered in any running firewall exceptions or firewall is disabled
sedae_1979 Sat, 12/01/2007 - 02:30
I dont understand why I dont make ping ASA device from my computer.
From Hyper terminal I make ping my compjuter.
ccbootcamp Sat, 12/01/2007 - 12:35
make sure you dont have a firewall installed on your pc that is blocking the tftp application.
-brad
www.ccbootcamp.com
(please rate the post!)
sedae_1979 Tue, 12/04/2007 - 11:05
You had right the firewall was the problem.
However I dawnload the asa721-k8.bin file in to device but there is the same problem.
ASA does not boot
