Router config
Answered Question
Nov 30th, 2007
This is a simple one. how how I reduce the time so the the telnet session won't time out on me?
Also, how do I get the router not to display or echo a statement after I do any modification. For example, after I change the configuration on an interface, the router echos the following: *Nov 30 09:14:25: %SYS-5-CONFIG_I: Configured from console by cisco on console". How do I disable the router from displaying this?
Thanks in advance,
sK
Correct Answer by Collin Clark about 9 years 2 months ago
For changing the telnet timeout. Try the following:
Router(config)#line vty 0 4
Router(config-line)#exec timeout 30
The 30 in the above statement is idle minutes before disconnect.
To remove any messages, type the following:
Router(config)#no logging monitor
HTH and please rate.
Overall Rating: 5 (1 ratings)
Correct Answer
Collin Clark Fri, 11/30/2007 - 09:46
Edison Ortiz Fri, 11/30/2007 - 10:16
Actually, the command is
no logging console
no logging monitor affects all monitored connections which include any SNMP logging traps among other things.
skhirbash Fri, 11/30/2007 - 22:43
You are correct. The no logging monitor didn't work but the no logging cosole worked.
sK
Collin Clark Mon, 12/03/2007 - 06:40
no logging monitor will shut off the messages during a telnet session and you got the console one figured out.
