Unable to delete the mistyped command when Dial-in
Nov 30th, 2007
  • Gold, 750 points or more
Hi All,
I have configured a USROBOTICS modem to 2801 forour network dial-in access. I used the simple config:
line aux 0
login local
modem InOut
modem autoconfigure type usr_courier
transport input all
speed 115200
flowcontrol hardware
Iam able to dial-in successfully to 2801, but when i try to 'backspace' or 'Delete' a mistyped command it gives me garble (small square boxes).I have hit 'CTRL C' and retype command again.
Any suggestions..?
Thank you
MS
Overall Rating: 4 (1 ratings)
mvsheik123 Tue, 12/04/2007 - 18:46
Thank you for quick reply. Did n't get chance to work on that. But, Iam sure it should fix the issue.
MS
