871W remote-access VPN Setup
Nov 30th, 2007
Hey. I'm trying to set up a basic VPN for a small business that has an 871W. The 871W says that it has two "free" VPN licenses. I can't seem to get it set up right. Any VPN guides out there? Any help is much appreciated.
JORGE RODRIGUEZ Fri, 11/30/2007 - 12:30
  • Green, 3000 points or more
These four links may be able to help.
Easy VPN Server feature on your router is for providing remote users the ability to VPN to your network using IPsec. The Easy VPN client allows for Lan-to-LAN VPN whereby you could statblish an IPsec encripted tunnel to either a router, pix, asa, or vpn concentrator at a remote site-network.
Details on Easy VPN Server
http://www.cisco.com/en/US/products/sw/iosswrel/ps1839/products_feature_guide09186a008055c37a.html#wp1276737
Easy VPN client - for Lan-to-LAN vpns etc..
http://www.cisco.com/en/US/docs/routers/access/800/850/software/configuration/guide/vpnezvpn.html
To learn more about your router and its features refer to this page.
http://www.cisco.com/en/US/products/hw/routers/ps380/products_data_sheet0900aecd8028a976.html
Q&A on license on table 1. and other questions on SSL/VPN
http://www.cisco.com/en/US/products/hw/routers/ps380/products_qanda_item0900aecd80323cba.shtml
Jorge
