ATM Swtiching Design Issue
Answered Question
Nov 30th, 2007
I want to use Cisco 3660 for atm aggregation. Like I have two IMA 4 port E1 Port adapter modules, ATM OC3, multimode Port adapter, 1 port and they all comes in the same chassis Cisco 3660. I want to know is it possible with Cisco 3660, Does 3660 support it if the answer is yes then how can I make cross connect between multiple IMA interfaces and OC3 interface in single chassis; and then further I can connect that OC3 interface to upstream OC3 router.
Correct Answer by Paolo Bevilacqua about 9 years 3 months ago
Na, that is not possible with a router.
For true ATM switching you need something like the LS-1010 that is not manufacred anymore. but very easy and cheap to buy used.
Overall Rating: 3 (1 ratings)
Correct Answer
Paolo Bevilacqua Fri, 11/30/2007 - 12:54
  • Hall of Fame,
    Founding Member
