Singly link
Nov 30th, 2007
Hi. Often i find written "a singly link" and i'm not able to figure out what this means. I'm italian so english is not my native language and i get confused if this generally means:
- one link
OR
- a link that can be used only in one direction
Sorry for the silly question and for my english ;)
Jon Marshall Fri, 11/30/2007 - 21:58
No apologies necessary.
I suspect it means "one link" rather than a link in only one direction which is usually described as a "unidirectional" link.
If you could give an example we might be able to help more.
Jon
Giugiogiu82 Sat, 12/01/2007 - 05:07
Hi, thanks for answering
I usually find it difficoult to answer the following question:
"How would you reverse a singly link?"
ccbootcamp Sat, 12/01/2007 - 11:41
Do you mean a single link? Or maybe a sickly link? If it's a single link, set it up on a date. Try adult friend finder or buy it a drink. If it's sickly, give it some anti-biotics.
-brad
