PIX 515 Will Not Read Flash Image
Nov 30th, 2007
Use BREAK or ESC to interrupt flash boot.
Use SPACE to begin flash boot immediately.
Flash boot in 8 seconds.
Can not use esc or break, it just keeps looping back to:
JORGE RODRIGUEZ Fri, 11/30/2007 - 20:24
  • Green, 3000 points or more
when using brake to interupt boot can you get to rommon> prompt? sounds you may need to upload new image.
rmwhite59 Sat, 12/01/2007 - 04:20
it does nothing when I use brake, it just tries to load the falsh and then loops back
sedae_1979 Tue, 12/18/2007 - 23:22
I think the problem is at confreg file.
Try to use BREK+SHIFT ore BREAK+CTRL
ccbootcamp Sat, 12/01/2007 - 12:32
  • Gold, 750 points or more
Have you tried changing the DRAM out? I've seen DRAM go bad in a 515 and it would cause something like this. The only other time I have seen this is with a dead 515.
-brad
www.ccbootcamp.com
(please rate the post!)
