Bandwidth for VT Advantage video calls
Nov 30th, 2007
Can anyone tell me how much bandwidth does a video call from VT Advantage camera consume?
Overall Rating: 4 (1 ratings)
rob.huffman Sat, 12/01/2007 - 08:36
Hi Pete,
Hope all is well with you!
IP Video Telephony SRND
Supported Video Codecs on Cisco VT Advantage
These video codecs are supported in Cisco VT Advantage.
H.263 (128 Kbps - 1.5 Mbps)
Cisco VT Camera wideband video codec (7 Mbps)
Cisco wideband, 7mps each direction for the highest quality. Or h.263 this ranges from 128Kbps up to 1536Kbps. The higher the bandwidth the better the quality.
Hope this helps!
rsefer Sun, 01/13/2008 - 23:00
Where can I set which codec used?
H.263? Wideband?
