how to Configure E1 interface
Nov 30th, 2007
We have purchased a router cisco 2821. I want to configure a E1 unchannelized (not PRI)interface for 2 MB of bandwidth. Please guide me from where i can get help URL to configure my E1 interface for 2 MB of bandwidth.
bvsnarayana03 Fri, 11/30/2007 - 21:15
  • Silver, 250 points or more
Just assign these commands on the interface:
(config-if)# bandwidth 2048
(config-if)# no shut
m_aurangzeb Fri, 11/30/2007 - 22:10
thanks bvsnarayana03 for quick reply. what about the other perameters of E1? if i keep it unassigned will it work? kindly tell me the URL?
thotsaphon Fri, 11/30/2007 - 22:57
  • Gold, 750 points or more
Hi Muhammad.
I'm not 100% sure that you can use full 2M because you only use 30 channels for doing that.
Are you using e1 for data? please try this:
card type e1 x/y
controller e1 x/y
channel-group 0 timeslots 1-31
interface serial x/y:0
encapsulation ??? (you want)
ip address ???(you want)
Note:Please let us know what type of card are you using?
If you really want to use 2M full I think you need E1 unframed G.703 to do.
Ref.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1834/products_feature_guide09186a00800e9762.html
Hopes that help
Thot
paolo bevilacqua Sat, 12/01/2007 - 06:18
  • Hall of Fame,
    Founding Member
As mentioned many many times, the bandwidth parameter is purely informative and does not change the speed of an interface or how it works.
