CISCO LAQ EQUIPMENT
Dec 1st, 2007
hi all.. ive recently passed my CCNA but im not exposed to the hardware on a daily basis but i start a new job in Feb using cisco equipment...in the meantime im thinkin of buying a lab with the following spec: and wanted to know if it was ok.. for £165'
Cisco 2520 Ethernet Quad Serial Router 16mb Flash / 16mb Dram / IOS 12.3
Cisco 2503 Ethernet Dual Serial Router 8mb Flash / 16mb Dram / IOS 12.1
Cisco 2610 Ethernet Router 8mb Flash / 32mb Dram with 2* WIC-1T= 2 serial interfaces / IOS 12.0
Switch
Cisco 1924-XL-EN 24 Port Ethernet Switch Catalyst 1900 Series
Accessories
1 x Ethernet transceivers for 2503
2 x serial DB60-DB60 crossover cables (DTE-DCE)
4 x power lead cables
2 x RJ45 / DB9 console cables
2 x WIC-1T serial modules with the 2610
Thanks to all who reply
Overall Rating: 5 (1 ratings)
ccbootcamp Sat, 12/01/2007 - 08:39
Swap out the 1924-XL for a 2950. upgrade the memory in the 2503 and 2610. Don't forget to add a terminal server (add a 2511 w/ octal)
Then you're all set for a decent starter lab.
-brad
www.ccbootcamp.com
(please rate the post)
solpandor Sun, 12/02/2007 - 11:37
Brad
thanks for that. Still unclear re terminal server? how do i get that?
also wot about this:
Routers
Cisco 2501 Ethernet Dual Serial Router 16mb Flash / 16mb Dram / IP Plus 12.3 IOS
Switch
Cisco 2924-XL-EN 24 Port Fast Ethernet Switch with latest Ver 17 Enterprise IOS
srue Sun, 12/02/2007 - 12:11
I opted for a different 'console' server.
I purchased an extra usb card and usb-to-serial adapters and made a bunch of roll over cables. So now I just open a bunch of different tabs in securecrt. This has a couple minor disadvantages over a true 25xx term server though.
1. most people use the console server to also inject routes (as a backbone router)
2. you don't get the 'experience' of getting used to the ctrl-shift-6-x key sequence.
ccbootcamp Sun, 12/02/2007 - 13:01
2511s are so cheap these days. Not only can you use them as a term server, but you can use them as a Backbone router to inject routes into your network or use it as a two-port FR switch. It's a GREAT addition to ANY home lab.
-brad
www.ccbootcamp.com
(please rate the post!)
ccbootcamp Sun, 12/02/2007 - 13:00
For the terminal server, you will want to buy a cisco 2511 or 2509 router with octal cable and ethernet xcvr.
-brad
www.ccbootcamp.com
solpandor Mon, 12/03/2007 - 00:47
further to my original post on home lab. what do u think of the spec below:
Routers
Switch
stefan.jagger Tue, 12/04/2007 - 05:55
Why not use simulation instead...?
Dynamips - Dynagen - GNS3 (search google)
Stefan
