Database Replication in CCM 5.1
Answered Question
Dec 1st, 2007
  • Cisco Designated VIP,
    2017 IP Telephony
How do I check that the status of Database replication in ccm 5.1.
When I issue the utils dbreplication status command, it points me to a file which I cannot read...
Correct Answer by allan.thomas about 9 years 3 months ago
From the cli if run the command 'file list activelog ' enter the path as output from dbreplication status to verify that it is there.
You can either enter file view activelog , and it would output the content the file to screen.
Or alternatively issue a file get activelog to upload the file.
Hope this helps.
Allan.
Overall Rating: 5 (1 ratings)
Correct Answer
allan.thomas Sat, 12/01/2007 - 04:06
  • Blue, 1500 points or more
Hope this helps.
Allan.
Ayodeji Okanlawon Sat, 12/01/2007 - 08:40
    2017 IP Telephony
Alan,
I will look at this on monday and let you know how it goes.
Ayodeji Okanlawon Mon, 12/03/2007 - 05:15
    2017 IP Telephony
Alan thanks I have been able to see this file as suggested.
I will formally ask to be a friend, you have been very helpful on this forum.
My name is Deji Okanlawon. I work with a cisco Gold Partner by name NSCGlobal in London.
My email is [email protected] and [email protected].
If you could drop me an email, I would love to keep in touch with you and learn from you!
One more thing,
Have you ever chekced the replication status on the Publisher using the utils dbreplication staus command? Each time I try to use it it takes forever and I have had to restart the server because I do not get a response in time.
