12-01-2007 03:55 AM - edited 03-05-2019 07:45 PM
Hello
Have anybody encounter a problem when an ospf neighbourship is being stuck in the EXSTART/DR ?
If yes how it is possible to fix this problem.
Thanks in advance
Lukas
12-01-2007 04:02 AM
Lukas,
Here is a link that might help. Is this between a router and a switch? It might be MTU mismatch.
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080093f0d.shtml
12-01-2007 04:07 AM
I have checked it but everything seems to be ok.
Both routers can ping each other, the MTU sizes are the same, both are connected to BROADCAST network and there is no ACL between them.
12-01-2007 06:11 AM
Generally Exstart- Exchange problems are due to mismatch, you may refer this link for similar problems & solution:
