CCVP CIPT 4.1 642-444 Exam
Answered Question
Dec 1st, 2007
Hi all,
I'm will be sitting the CCVP exam 642-444 CIPT 4.1 on Monday. I would appreciate it very much if anyone can suggest any topics that I should focus on etc.
Martin
Correct Answer by ccbootcamp about 9 years 1 month ago
Call Manager! :)
Seriously though, look at the blueprint closely:
http://www.cisco.com/web/learning/le3/current_exams/642-444.html
The exam is pretty much inline with the blue print.
-brad
www.ccbootcamp.com
Overall Rating: 4.5 (2 ratings)
martinward1234 Sun, 12/02/2007 - 03:25
Thanks for the suggestion, I have attended to two CIPT courses and there is so much covered that it is easy to begin to worry about which areas I need to brush up on.
swrsmaster Sat, 12/01/2007 - 10:46
Let me know how you do on your exam. I am going to take the same test in a month or so.
