ivan_tushev Sun, 12/02/2007 - 02:53
I'm afraid you're wrong:
c4948#sh vlan ?
access-map Vlan access-map
brief VTP all VLAN status in brief
dot1q Display dot1q parameters
filter VLAN filter information
id VTP VLAN status by VLAN id
ifindex SNMP ifIndex
internal VLAN internal usage
mtu VLAN MTU information
name VTP VLAN status by VLAN name
private-vlan Private VLAN information
remote-span Remote SPAN VLANs
summary VLAN summary information
| Output modifiers
glen.grant Sun, 12/02/2007 - 10:59
  • Purple, 4500 points or more
Well that certainly is interesting seeing that it is part of the 4500 series switch command and the 4948's use the 4500 code . What code version is that running ? Looks like it has been there since 12.1.13EW if your code is older than that then it won't show up .
show vlan counters
To display the software-cached counter values, use the show vlan counters command.
show vlan [id vlanid] counters
Syntax Description
id vlanid
(Optional) Displays the software-cached counter values for a specific VLAN.
Defaults
This command has no default settings.
Command Modes
Privileged EXEC
Command History
Release
Modification
12.1(13)EW
Support for this command was introduced on the Catalyst 4500 series switches.
Usage Guidelines
If you enter the show vlan counters command without specifying the VLAN ID, the software-cached counter values for all VLANs are displayed.
Examples
This example shows how to display the software-cached counter values for a specific VLAN:
Switch# show vlan counters
* Multicast counters include broadcast packets
Vlan Id : 1
L2 Unicast Packets : 0
L2 Unicast Octets : 0
L3 Input Unicast Packets : 0
L3 Input Unicast Octets : 0
L3 Output Unicast Packets : 0
L3 Output Unicast Octets : 0
L3 Output Multicast Packets : 0
L3 Output Multicast Octets : 0
L3 Input Multicast Packets : 0
L3 Input Multicast Octets : 0
L2 Multicast Packets : 1
L2 Multicast Octets : 94
Switch>
ivan_tushev Sun, 12/02/2007 - 11:33
I know that it uses 4500 IOS but seems like Cisco decided that such a device won't need any hardware counters for vlans (I doubt that software counters for gig 48ports is good idea).
Here is the "show ver" dump:
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500-ENTSERVICESK9-M), Version 12.2(37)SG1, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Mon 30-Jul-07 13:47 by prod_rel_team
Image text-base: 0x10000000, data-base: 0x11863D38
ROM: 12.2(20r)EW1
Dagobah Revision 226, Swamp Revision 5
