CCVP home lab
Answered Question
Dec 1st, 2007
What hardware and software should I have in my voice home lab?
Correct Answer by ccbootcamp about 9 years 1 month ago
For a CCVP home lab, I suggest the following:
• 2 Cisco 2811s (HQ, Branch 1)
BR1:
2x PVDM2-8
VWIC-1MFT-T1
WIC-1T
NM-16ESW-PWR
2811 IP Telephony power supply
HQ:
1x PVDM2-8
VWIC-1MFT-T1
WIC-1T
VIC2-2FXS
• 1 Cisco 3725 (Branch 2)
NM-CUE (not needed for CCVP but fun to play with)
NM-HDV (w/ 2 PVDM-12 modules)
VWIC-1MFT-E1
WIC-1T
• 1 Cisco 2811 for PSTN/WAN cloud
VWIC-2FT-T1
VWIC-1MFT-E1
NM-4A/S
• 2 Cisco Catalyst 3560 w/ POE running EMI code
• 7 Cisco 7960G IP Phones
• 1 Server w/ CallManager 4.1(3)
• 1 Server w/ Unity 4.0(5)
• 1 Cisco 2511 w/ Octal Cable and Ethernet Transceiver (For reverse telnet / terminal server)
This will be a very nice lab setup for you to build on to continue to CCIE Voice. You'll add a CCM sub, vg248, and cat6503 and you'll have a perfect ccie voice lab! :) (although the vg248 and cat6503 are very expensive!)
For the software (CCM) I suggest you use a VMWare image. It will make your life much easier.
You can also switch some of the devices for cheaper devices. For example, a 2610XM router for the HQ and BR1. Change the BR2 to a 2610XM and drop the NM-CUE module (dont need it for CCVP). Change the PSTN to a 3640. Just make sure you get the proper NM-HDV's if you change from a 2800 to a 2600XM. :)
-brad
www.ccbootcamp.com
(please rate the post!)
Overall Rating: 5 (3 ratings)
Correct Answer
ccbootcamp Sat, 12/01/2007 - 11:34
BR1:
2x PVDM2-8
VWIC-1MFT-T1
WIC-1T
NM-16ESW-PWR
HQ:
1x PVDM2-8
VWIC-1MFT-T1
WIC-1T
VIC2-2FXS
VWIC-1MFT-E1
WIC-1T
VWIC-2FT-T1
VWIC-1MFT-E1
NM-4A/S
-brad
www.ccbootcamp.com
swrsmaster Sat, 12/01/2007 - 11:51
What would be the absolute bare minimum I could use for a CCVP home lab before I attend the boot camp?
