crs 5.0 initial setup problem
Dec 1st, 2007
Hi;
We have CM 5.1. I installed CRS 5.0 on a MCS 7835 server(win 2003+SP2). At initial setup phase; after i installed the license i took approximately one hour to activate the components. When it finished; there was a problem with unified CM telephony client. When i open <server>/appadmin, an error popup says; there is inconsistency about unified cm client and recommends to resynchronize. When i try to resynchronize (Unified CM Telephony menu), it takes approximately half an hour to finish and at last it cannot synchronize. It says " an error occured".
Network connection between CM and UCCX is very good. They are one the same switch and on same subnet. Pings are normal.
Chris Deren Sun, 12/02/2007 - 14:30
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
UCCX 5.0 is supported with CUCM 5.1.
Check the MIVR logs for more details.
Is the JTAPI users setup properly?
Chris
michael.huelskoetter Thu, 02/21/2008 - 02:06
Hello Murat!
Do you still have the Problem with the CRS?
If not, how do you solve it?
We're using CRS 5.0.1 with CM 6.0 and we have the same Problem.
kind regards
Michael
cjrchoi11 Fri, 03/21/2008 - 19:14
I have same issue and please let me know if anyone resolved.
-CRS 5.0(1)_Build433
-CUCM 6.0
Thanks in advance,
John
Chris Deren Fri, 03/21/2008 - 20:58
  • Hall of Fame,
For me the problem was that during the installation I pointed the RmCm service to 4 providers (CM servers) however only 2 are supported, after changing the config to point to 2 servers all was fine.
Chris
alexander.teske Tue, 04/01/2008 - 06:59
In our system it points to one CM 6.0 server and we habe also the problem with the inconsistens. Did anyone solve the problem?
alex
