Anyconnect with Cisco ACS
Dec 1st, 2007
Has anyone been able to get anyconnect to work properly with ACS? The problem that I am having is that I want users to be able to download the Anyconnect client from the Webvpn page. When I have them log onto the Webvpn page by authenticating with ACS (using radius protocol), the Anyconnect client is not available for download on the left hand side of the Webvpn options. However, if I configure the ASA to use a local username and password and do the following commands : "username test attributes" "vpn-group-policy HQ-SSLVPN" then the Anyconnect client is available for users to download on the Webvpn page. This is the relevant configuration that I am using:
webvpn
enable outside
svc image disk0:/anyconnect-win-2.1.0148-k9.pkg 1
svc enable
group-policy DfltGrpPolicy attributes
dns-server value 192.168.0.15
vpn-tunnel-protocol IPSec l2tp-ipsec svc webvpn
ipsec-udp enable
nac-settings value DfltGrpPolicy-nac-framework-create
address-pools value vpn-pool
webvpn
svc ask enable default svc
group-policy HQ-SSLVPN internal
group-policy HQ-SSLVPN attributes
vpn-tunnel-protocol svc webvpn
address-pools value svc-full-tunnel
webvpn
url-list value test-list
svc dtls enable
svc keep-installer installed
tunnel-group DefaultWEBVPNGroup general-attributes
address-pool svc-full-tunnel
authentication-server-group radius-acs
default-group-policy HQ-SSLVPN
tunnel-group HQ-SSLVPN type remote-access
tunnel-group HQ-SSLVPN general-attributes
When I am debugging the output, I do notice one difference. When the ASA is using ACS to authenticate it shows that AAA retrieve user specific group policy (HQ-SSLVPN). However, when the ASA just uses the local username and password, it says that AAA retrieved user specific group policy (HQ-SSLVPN) and right afterwards it says that AAA retrieved default group policy (DfltGrpPolicy).
Also, when I have the ASA configured to use ACS, if the person does already have the Anyconnect client installed on their computer and they try to login in using Anyconnect, it comes back with an error stating "Anyconnect is not enabled on the VPN Server". Of course, this goes away once I have them authenticating to the local ASA database. Any help or insite would be greatly appreciated.
Jason
Overall Rating: 5 (1 ratings)
Jason Gervia Mon, 12/03/2007 - 13:58
For netpro's benefit - RADIUS attributes (group policy, tunnel protocol) etc. will override the settings set on the ASA - that's what was happening here.
--Jason
