DFM devices in Questioned status
Dec 1st, 2007
I'm using LMS 2.5 and DFM 2.0.3. I'm not able to discover the devices, the data collector process stops at 40% and after some time shows error message: datacollector request timeout. going into questioned state.
Any help..
Joe Clarke Sun, 12/02/2007 - 00:11
This could be an SNMP timeout problem. Try increasing the timeout under DFM > Device Management > SNMP Config.
aijaz802 Sun, 12/02/2007 - 02:03
The SNMP is configured properly, as the archive mgmt, fetching configs.
The processes are seems to be running normal.
Its coming under the others section...
The error message is below.
*** Data Collector Status Information ***
Error Code = Others
Error Message = DataCollector request timeout(internal problem)
Joe Clarke Sun, 12/02/2007 - 09:30
This could be a process problem, then. Please post the output of pdshow.
NorthgateIS Tue, 12/04/2007 - 04:43
Have seen similar problems here when remote devices, particularly AP's have been turned off before the data collector see's the devices as known.
I usually ping the device to ensure it is reachable and then click on the checkbox for the devices and do a "rediscover". Sometimes takes a couple of times before the devices are known.
Joe Clarke Sun, 12/09/2007 - 10:22
Some internal debugging will need to be enabled, and logs collected. You should open a TAC service request to proceed at this point.
