ACE: dropped conns due to header insert
Answered Question
Dec 2nd, 2007
My LB is dropping connections on port 443 when I have "insert-http source header-value "%is" configured. Other ports such as 80, or 8080 are working. The config is the same for all ports.
class-map match-any Service_VIP_Class
4 match virtual-address 1.1.1.1 tcp eq https
policy-map type loadbalance first-match Service_L7_Policy
class class-default
serverfarm Service_Serverfarm
policy-map multi-match Service_LB_Policy
class Service_VIP_Class
loadbalance vip inservice
loadbalance policy Service_L7_Policy
loadbalance vip icmp-reply active
loadbalance vip advertise active
I see dropped conns on the service policy. When I remove the header insertion config, it connects ok.
Please help!
Correct Answer by Syed Iftekhar Ahmed about 9 years 2 months ago
There is no way any device (including ACE) can open an https packet to insert anything.
Only exception:
You offload ssl using server keys and certs.Then make changes to the decrypted packet.
Syed
Overall Rating: 5 (1 ratings)
Correct Answer
Syed Iftekhar Ahmed Sun, 12/02/2007 - 11:57
Only exception:
Syed
