InterVlan Routing On L3 Switch and NAT On another Router
Dec 2nd, 2007
Hi All,
Not sure if this can be done
ISP----------Router--<L3 Port>--L3 SW--------------------Intenal Network
Router Config:
access-list 1 permit
ip nat inside source list 1 interface <WAN> overload
interface <WAN>
ip address
ip nat outside
no shut
interface <LAN>
ip address
ip nat inside
no shut
ip route
ip route
Switch Config:
ip routing
interface fa0/1
no switchport
ip address
no shut
interface VLAN 10
ip address
no shut
interface range fa0/2-24
switchport mode access
switchport access vlan 10
spanning-tree portfast
no shut
From the PC, I am not able to access the internet. nor can i do a NAT translation on WAN Router.
btw, Layer 3 Switch does not allow us to configure NAT.
Help is greatly appreciated.
Yen Lung
Jon Marshall Sun, 12/02/2007 - 04:28
Hi Yen
Do you have a deault route on your L3 switch pointing to ?
yenlung Sun, 12/02/2007 - 05:33
Oh yes, I had put it down in my config.
Still not working...
thotsaphon Sun, 12/02/2007 - 04:35
Hi Yen.
- Can you do ping command from hosts to
- Can you resolve names from the DNS server?
From hosts : C:\>nslookup
Hopes that help
yenlung Sun, 12/02/2007 - 05:35
i had forgetten the ip route on the above.
I had put that in in my L3 SW.
I could not test that, as it is a internal Lab.
but, from the PC, I am able to ping to the WAN Interface.
No NAT translation.
yenlung Mon, 12/03/2007 - 01:13
Any one can help me with this?
It seem to be a simple problem. what am i missing?
Jon Marshall Mon, 12/03/2007 - 01:36
Hi yen
Firstly are you sure packets are getting to the router from the switch.
if so, can you run a "debug ip nat" on the WAN router to see what is happening.
Be careful with debug commands as they can affect the performance of the router.
yenlung Mon, 12/03/2007 - 06:26
Ok ... Problem solved,
One quick question...
When I ping the WAN Router Outside interface, from the Inside Interface, I get a NAT translation.
however, once i go to the l3 switch, and ping the WAN router outside interface, I do not get a NAT translation.
