ip phone dirctory button configuration
Dec 2nd, 2007
hi,
how can we configure directoy button, i wanted to get dc directory searching option, means user press directory button then he wanted to search user names and numbers
how can configure these options, can u pls help me
regds
sunish
Chris Deren Sun, 12/02/2007 - 16:54
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
There is nothing to it, simple configure the users in CallManager with telephone number field filled out.
Then on the phone press Directories--> Corporate Directory and search for the user.
HTH,
Chris
sunishnair Sun, 12/02/2007 - 20:39
hi
this is i know, but i wanted to know how can configure these option in ccm that i want
Regds
stn
Chris Deren Mon, 12/03/2007 - 05:08
  • Hall of Fame,
What options?
sunishnair Mon, 12/03/2007 - 05:14
hi,
i wanted to know how can we configure corparte directory option on ccm, then i wanted to know we wanted to configure these option for each phone or not
sunish
Tommer Catlin Sun, 12/09/2007 - 10:52
  • Green, 3000 points or more
CUCM's directory is not really configurable. It's a basic directory that either uses LDAP in AD or built in Cisco Directory. You can not create your own custom directory, or multiply directories, etc. If you want to do that, you will need to purchase a third party tool, or develop some XML applications for your IP phone services. There are a number of companies that can help out with that.
- Citrix Application Gateway. (express directory is really cool)
- IP Celerate
- LiteScape
cheers
