12-02-2007 08:24 AM - edited 03-05-2019 07:46 PM
hello experts!
i entered the command EIGRP Stub under the eigrp AS.but i do not find it when i issue sh run?
10xs
12-02-2007 08:50 AM
Do you have a frame-relay connection on this router ?
If so, all spokes must have EIGRP Stub configure with the exception of the hub.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124cr/hirp_r/rte_eih.htm#wp999335
12-02-2007 08:56 AM
hello freind
10xs
12-02-2007 08:59 AM
NO I DONT HAVE FRAME-RELAY
12-02-2007 09:07 AM
Can you post your config along with explanation of your network topology (what kind of connections this router has)?
As noted in the URL I posted, Ethernet connections will also be affected with the EIGRP stub.
12-02-2007 09:41 AM
HI
ETHERNET CONNECTION THE HAVE.
12-02-2007 09:12 AM
Do you mean EIGRP stub router functionality?
http://www.cisco.com/en/US/tech/tk365/technologies_white_paper0900aecd8023df6f.shtml
usage in eigrp
cisco-2621-rtr(config)#router eigrp 1
cisco-2621-rtr(config-router)#eigrp stub
Jorge
12-02-2007 09:42 AM
10XS FOR UR HELP JORGE
