MPLS VPN and per packet or per destination
pooria_koleyni
I have 2 PEs connected to 2 P routers
Also PEs are connected to each other
We are using OSPF and IGP
What is effect of using per packet or per destination on MPLS L3 VPN ?
and which one is recommended ?
rhx
swaroop.potdar
Level 7
Level 7
Per packet or per destination would not be only relevant to VPN traffic, but for all traffic which uses CEF as a forwarding method.
Per destination is default in cef, and you can set it to per packet, but per packet would not be recommended as a thumb rule, as it can result into out of sequence packets.
Although you can choose to use per packet on a per case basis where, both the paths involved are of similar lateny or for traffic which is not delay sensitive.
HTH-Cheers,
Swaroop
