WAE software question
Answered Question
Dec 2nd, 2007
i have read in the WAE manual that all 3 devices must have the same software version. what will happend if the 3 device have different versions?
exp.
Core & Edge = 4.0.13.b.12
CM = 4.0.13.b.23
rgds,
ben
Correct Answer by Zach Seils about 9 years 4 months ago
Ben,
It is not required that all WAEs are running the same version, it is merely a recommendation. The only requirement is that the CM is running the lowest version.
Zach
Overall Rating: 5 (1 ratings)
Correct Answer
Zach Seils Mon, 12/03/2007 - 06:56
  • Cisco Employee,
Ben,
Zach
