Topology for CCIE R&B lab
Answered Question
hi guys,
Do you know where i can find any place there are document providing any topology and questions?
thanks,
Han,
Correct Answer by ccbootcamp about 9 years 5 days ago
Main disadvantage is the IOS you can run. With a 2500, you're going to be limited to running 12.2 vs with a 2800 you can run the latest and greatest code. If all you can afford is the 2500, then go for it. It will still be a great tool for you.
-brad
www.ccbootcamp.com
(please rate the post if this helps!)
Correct Answer by ccbootcamp about 9 years 6 days ago
I only have an older sample lab that doesn't have the current topology. Give me a couple weeks, and I'll put a new one up and send you the link when it's ready. :)
-brad
www.ccbootcamp.com
Overall Rating: 4.9 (8 ratings)
ccbootcamp Mon, 12/03/2007 - 10:23
If you want a sample topology:
1) hardware we use:
http://www.ccbootcamp.com/racks/config1.html
2) layer-1 we use:
www.ccbootcamp.com/racks/rack1.pdf
If you are just getting started, and want to work on developing a good understanding of the core technologies, I high recommend the technology workbook:
www.ccbootcamp.com/ccierslw-tech.html
Also, if you are just starting to prepare for your lab exam, make sure to review the approach and methodology:
www.ccbootcamp.com/collateral/ccbootcamp-rs-approach-method.pdf
-brad
www.ccbootcamp.com
(please rate the post!)
Correct Answer
ccbootcamp Mon, 12/03/2007 - 15:39
-brad
www.ccbootcamp.com
Correct Answer
ccbootcamp Tue, 12/04/2007 - 08:39
-brad
www.ccbootcamp.com
