BGP maximum path in route reflectors
Answered Question
Dec 3rd, 2007
I have RR in MPLS VPN . they are not part of mpls vpn . they only act as RR
each MPLS L3 VPN has 2 next hop and all are in RR VPN4
But one of 2 routes are in PEs
I want to use BGP load sharing using the following command
address-family ipv4 [mdt | multicast | tunnel | unicast [vrf vrf-name] | vrf vrf-name] | ipv6 [multicast | unicast] | vpnv4 [unicast]
5. maximum-paths eibgp number [import number]
i have heard that this command is not supported in RR
Is it correct and if yes what will be the solution
thx
Correct Answer by mheusing about 9 years 2 months ago
You are right, load sharing this way will not work today. The underlying reason is the way BGP is designed. RFC 4271 clearly states: "In the context of this document, we assume that a BGP speaker advertises to its peers only those routes that it uses itself (in this context, a BGP speaker is said to "use" a BGP route if it is the most preferred BGP route and is used in forwarding). All other cases are outside the scope of this document."
As a RR is a BGP speaker it will only announce the best route. This is not configurable, but part of the standard.
Especially in an MPLS network the solution thus is: let two identical IP networks look different by using two different route-distinguisher. This is very much the same idea as why to have RDs in the first place: let an IP network used by different customers look different to BGP by prepending unique 64 Bit. Now we let the prefix look different to the BGP path selection of a RR.
Example config for a dual homed CE:
At PE1:
ip vrf CE11
rd 65000:1011
route-target export 65000:11
route-target import 65000:11
router bgp 65000
address-family ipv4 vrf CE11
neighbor 10.1.11.2 remote-as 65011
neighbor 10.1.11.2 activate
maximum-path unequal-cost ibgp 2 import 2
no auto-summary
no synchronization
network 10.1.11.0 mask 255.255.255.252
exit-address-family
At PE2:
ip vrf CE11
rd 65000:2011 !<--- note the different RD but identical RTs
router bgp 65000
neighbor 10.2.11.2 remote-as 65011
neighbor 10.2.11.2 activate
no auto-summary
no synchronization
network 10.2.11.0 mask 255.255.255.252
exit-address-family
So in general, every PE should have a unique set of RDs to allow for load sharing along the example given above. Be aware, that this will increase the memory requirements, because every VPNv4 prefix will at least be stored twice in the VPNv4 table, one with original RD, and one imported one per VRF.
Hope this helps! Please rate all posts.
Regards, Martin
Overall Rating: 5 (3 ratings)
Correct Answer
mheusing Mon, 12/03/2007 - 05:18
At PE1:
ip vrf CE11
rd 65000:1011
router bgp 65000
no auto-summary
no synchronization
exit-address-family
At PE2:
ip vrf CE11
router bgp 65000
no auto-summary
no synchronization
exit-address-family
Regards, Martin
