What's the meaning of Po1 port type?
Dec 3rd, 2007
I am doing a sh mac-address-table in Cisco Catalyst 3750 switch and I don't know what's the meaning of Po1 in the type of port.
Anybody can say me it?.
This is a line of cmmand output.
11 0013.c3bb.4185 DYNAMIC Po1
Overall Rating: 2.8 (5 ratings)
royalblues Mon, 12/03/2007 - 04:02
you must have configured etherchannel in your switches.
Po1 means that the MAC is learnt from a port channel interface
mirtenmous Mon, 12/03/2007 - 04:27
Ok thanks.
I would like to know in what port number is the device with this MAC.
Is it possible?.
glen.grant Mon, 12/03/2007 - 04:27
It means the mac address is being learned over port-channel 1 .
royalblues Mon, 12/03/2007 - 04:35
Since the MAC is from a PO1 interface, it is mostly being learnt from the uplink to another switch
See what switch is connected on the other side of the port channel and then issue the command to get the port.
sh mac-address-table address 0013.c3bb.4185
It is quite possible that you may have to repeat this excercise upto the edge switch where the device is connected.
mirtenmous Mon, 12/03/2007 - 07:24
I entered sh mac-address-table address 0013.c3bb.4185 command in my core switch and now port is Po3.
I don't know where I must to do know to find it because this is my core switch
Edison Ortiz Mon, 12/03/2007 - 06:10
As Narayan stated, Port-Channel1 is a logical interface created when Etherchanneling is configured.
To find the physical interfaces that are member of that port channel, execute the show etherchannel summary command.
Once you find the interfaces, you can execute a show cdp nei to find the switch that is originating this MAC Address.
Telnet to that switch and execute the show mac-address-table command once again to find the egress port.
mirtenmous Mon, 12/03/2007 - 07:30
My core switch and a voice gateway is in the etherchannel group how I can see with commands that you say me.
I find thi MAC in core switch and now in type of port of this MAC it shows Po3 but I don't know where I must to see know because this is my core switch and I think that it is no more switch in etherchannel group.
Jon Marshall Mon, 12/03/2007 - 07:37
Well actually Edison has given you the answer. Hopefully it wasn't you that rated the post as 1 as Edison's answers was, as usual, very helpful.
If the mac-address is on Po3
sh etherchannel summary
this will list all Po interfaces and the physcial interfaces that make up each Po logical interface. So lets assume gi1/2 is one of the physical interfaces
then you do
1) sh cdp neigh g1/2 det
this should give you the IP address of the switch at the other end of Po3.
The above assumes you are running CDP and that you have management addresses on the switch.
mirtenmous Mon, 12/03/2007 - 08:02
I am sorry to say you that your post and the Edison post are not helpful
I repeat your procedure from first switch where this MAC appear and I could discover the last switch in ehterchannel group but It isn't wanted MAC there.
