PBR using Nbar Protocol discovery
Hi as the title suggests i wish to use Nbar at layer 7 to qualify traffic for PBR. But i cannot see a direct way to use the Nbar protocols in a route map.
One way i have found to do this is to class map the traffic and assign a dscp tag, then use the dscp tag in conjuction with the pbr route map and access lists.
Thanks in advance for your time.
Edison Ortiz Mon, 12/03/2007 - 08:54
  • Hall of Fame,
    Founding Member
I believe your current workaround is the best approach at the moment as there isn't any NBAR support under route-maps.
