4240 memory question
Answered Question
Dec 3rd, 2007
I have a 4240 IPS unit and it is using 1371 out of 1893 and only has 522 left and it is climbing. Is this normal and if it is not how do I clear the memory so it is not using so much memory?
Correct Answer by mhellman about 9 years 1 month ago
They will tend to use all available memory. Unless you start swapping to disk, don't worry about it.
Overall Rating: 5 (1 ratings)
Correct Answer
mhellman Mon, 12/03/2007 - 06:44
