2811 + 2 DSL + NAT with Load sharing ?
Answered Question
Dec 3rd, 2007
I have searched these forums, and the cisco site, but cant seem to find a suitable solution to my situation, which I believe is very common.
I am using a 2811 with a DSL HWIC, and using NAT.
Now I want to attach another DSL line, but also want to dynamically load balance between the 2 ISP's so that my LAN users can get higher speeds.
Multilink PPP is not an option (as I have 2 ISP's).
I know that policy based routing can help me a bit, but I cant seem to figure out how this would affect NATing.
Any pointers would be appriciated.
Correct Answer by Paolo Bevilacqua about 8 years 10 months ago
this is your configuration example:
you can omit the tracking part if your Layer1 / layer2 interface status is reliable, and just add a 2nd default route.
Overall Rating: 5 (1 ratings)
