PIX535 VPN Remote peer issue
husycisco Mon, 12/03/2007 - 06:28
  • Gold, 750 points or more
Hi russell
How do you dedect that it picks a wrong IP? Any syslog output?
Hi - normally the cusomer lets us know that it has stopped working and issueing the command "sh crypto ipsec sa" confirms that the peer is 50.0.0.0
(local ident (addr/mask/prot/port): AXA_ftpap001/255.255.255.255/0/0)
remote ident (addr/mask/prot/port): (192.168.1.1/255.255.255.255/0/0)
current_peer: 50.0.0.0:0)
local crypto endpt.: TheAAPIX_Peer, remote crypto endpt.: 50.0.0.0
After a reboot the same command outputs the correct peer information (AXA_Peer) for about a week then the same thing happens again.
Here is the releavant config for this connection. Line 2 on the ACL is the only one that gets used.
name x.x.x.x AXA_Peer
name x.x.x.x AXA_ftpap001
access-list AXA permit tcp host 192.168.1.1 host AXA_ftpap001 eq 1363
access-list AXA permit tcp host 192.168.1.1 host AXA_ftpap001 eq 1364
access-list AXA permit tcp host TheAA_FTP host AXA_ftpap001 eq 1363
access-list AXA permit tcp host TheAA_FTP host AXA_ftpap001 eq 1364
access-list AXA permit ip host 192.168.1.1 host AXA_ftpap001
access-list AXA permit tcp host AXA_ftpap001 host 192.168.1.1 eq 1364
access-list AXA permit tcp host AXA_ftpap001 host 192.168.1.1 eq 1363
access-list AXA permit ip host AXA_ftpap001 host 192.168.1.1
access-list AXA permit tcp host AXA_ftpap001 host TheAA_FTP eq 1363
access-list AXA permit tcp host AXA_ftpap001 host TheAA_FTP eq 1364
access-list AXA permit ip host AXA_ftpap001 host TheAA_FTP
access-list AXA1 permit ip host TheAA_FTP host AXA_ftpap001
static (dmz_v905,outside) 192.168.1.1 access-list AXA1 0 0
crypto map aa3party 250 ipsec-isakmp
crypto map aa3party 250 match address AXA
crypto map aa3party 250 set peer AXA_Peer
crypto map aa3party 250 set transform-set aa
isakmp key ******** address AXA_Peer netmask 255.255.255.255 no-xauth no-config-mode
crypto ipsec transform-set aa esp-3des esp-md5-hmac
ajagadee Mon, 12/03/2007 - 06:48
  • Cisco Employee,
Can you provide some additional information on this issue.
Also, make sure that you dont have Overlapping Access-list, meaning same destination network configured for two different peers.
Arul
I have just rebooted the PIX and as you can see below the correct peer information is there and the file transfer is now working.
local ident (addr/mask/prot/port): (AXA_ftpap001/255.255.255.255/6/0)
remote ident (addr/mask/prot/port): (192.168.1.1/255.255.255.255/6/1364)
current_peer: AXA_Peer:0
PERMIT, flags={origin_is_acl,reassembly_needed,}
#pkts encaps: 0, #pkts encrypt: 0, #pkts digest 0
#pkts decaps: 0, #pkts decrypt: 0, #pkts verify 0
#pkts compressed: 0, #pkts decompressed: 0
#pkts not compressed: 0, #pkts compr. failed: 0, #pkts decompress failed: 0
#send errors 0, #recv errors 0
local crypto endpt.: TheAAPIX_Peer, remote crypto endpt.: AXA_Peer
path mtu 1500, ipsec overhead 0, media mtu 1500
current outbound spi: 0
inbound esp sas:
inbound ah sas:
inbound pcp sas:
outbound esp sas:
outbound ah sas:
outbound pcp sas:
