Capturing FWSM-sourced traffic
Dec 3rd, 2007
Has anyone suggestions as to the best way to capture traffic sourced from a FWSM module running 3.2(3).
I have tried the capture feature but this may only work on traffic across the box.
Mark
If you cannot capture the traffic using the capture feature by specifying some tight acl's then you may want to throw in a sniffer if that is possible. You would get more information than the FWSM capture would provide even if it did work. Maybe too much even. I have had a couple of FWSM issues that only sniffers could capture.
