Can you change CCMadministrator password from OS level
Hi All,
I am doing a new install of CM 5.1(3). I can access the console of the system with administrator.
I cannot login through the webpage though. I was pretty careful to use the same password for the accounts but it looks like i might have type it in wrong as i get the "Login failed" screen
the password i used has a space in it. Is that ok to use? it works on the linux pwd
is there a way to change the ccmadministrator password from the linux prompt?
mchandak Mon, 12/03/2007 - 11:08
Yes, you can reset the password for CCMAdministrator from the console. The command for the same is:
"utils reset_ui_administrator_account".
Once this command is run, it would reset the password for CCMAdministrator GUI account.
Hope this helps
It looks like I can change the password on the linux no problem using a "space" in the password
but it won't let me login through the web access with a space in the password. I changed the password to have no space and it works fine.
Any reason why a space can't be used to login? it accepts it but the webpage won't let you login.
mchandak Mon, 12/03/2007 - 11:25
space is not a valid character in the password field and I dont think it does a check to see for the space.
