6500 VSS
Dec 3rd, 2007
Guys
I want to know when should I recommend the 6500 VSS and when to recommend the plain 6500's? If there are only advantages to going with VSS, why would anybody recommend the separate 6500's at the core solution?
1) Also, is there a risk going with a new product like the VSS or does Cisco have some documented case studies with customers already running it?
2) Can one use the 6500 VSS and install two switches in a traditional way using HSRP?
Thank you
Edison Ortiz Mon, 12/03/2007 - 18:06
  • Hall of Fame,
    Founding Member
1) Purchasing such device and placing it in a Lab environment with your current configuration would be the correct course of action.
2) Yes.
ciscors Mon, 12/03/2007 - 18:09
am i right that the VSS allows each 6500 switch to contain only one supervisor?
Edison Ortiz Mon, 12/03/2007 - 18:19
  • Hall of Fame,
    Founding Member
Yes. You need Supervisor 720-10G though.
ciscors Tue, 12/04/2007 - 12:00
Now that VSS is out, I'm building this design into my routed access design (L3 to the edge) and had some questions
1) Instead or running equal-cost EIGRP paths from each 3750 access switch stack, should I just run an MEC to both cores?
2) Is the VSS link (I'm using 2 10GB links) to be used only for control plan or data traffic too? Would this link be a L2 or L3 link?
3) Does anything else change in terms or design?
ciscors Tue, 12/04/2007 - 12:01
Also, would my 3750 links to each 6500 be layer 2 MEC links or L3 MEC links?
Shobith K Thu, 12/27/2007 - 02:10
It will be L2 MEC links. Also by implementing this way, you can get rid of STP and HSRP in your environment. Also these links can be loadshared. The links from the 3750 access towards the core would be running MultiChassis EtherChannel.
