ASA CSC SSM Download Delay
Dec 3rd, 2007
I am new to the ASA and CSC SSM module. I am experiencing delays when downloading any type of file from the web. It appears that the download takes place in the background and, depending upon the size of the download, takes anywhere between 1 and 5 minutes for the download dialog to appear. Once it appears, however, the download is instant. Has anyone experierence this issue and if so has there been a solution to this problem? This wouldn't be a problem but the end users think there is something wrong and so they hit download over and over and over again.
ccbootcamp Tue, 12/04/2007 - 07:57
hmm...I had an ASA w/ a CSC module installed but didn't have any issues with what you are saying. If you disable the CSC module, do you still have the same problem?
-brad
www.ccbootcamp.com
(please rate the post if this helps!)
brianinms Thu, 12/06/2007 - 12:29
What options do you have configured for File Scanning? Is internet surfing speed the same?
