Looking for TCL-Script (CME) for "out of business" message
Dec 3rd, 2007
Hi all,
I'm looking for a basic TCL-Script for only associate an audio.au file to a phone-nr.
Tried with B-ACD/AA from CCME but is too oversized for my purpose.
Any ideas?
Norbert
Overall Rating: 5 (1 ratings)
paolo bevilacqua Mon, 12/03/2007 - 18:43
  • Hall of Fame,
    Founding Member
Hi Norbert,
this would be minimal script that does that.
proc act_Setup { } {
leg setupack leg_incoming
leg proceeding leg_incoming
leg connect leg_incoming
media play leg_incoming disconnect.au
proc act_Close { } {
call close
set fsm(any_state,ev_disconnected) "act_Close same_state"
set fsm(any_state,ev_media_done) "act_Close same_state"
set fsm(INIT,ev_setup_indication) "act_Setup same_state"
fsm define fsm INIT
alig.norbert Tue, 12/04/2007 - 00:02
Hi Paolo,
Thanks for the script.
Is there no way to reload a TCL-Script without rebooting the whole router?
Greets,
Norbert
paolo bevilacqua Tue, 12/04/2007 - 07:08
  • Hall of Fame,
    Founding Member
You can reload the script, the problem is with the audio files when loaded from flash.
I've found that these become sticky and no command helps. One workaround is changing the name of the file in the script.
