Problem loading Java (rdp) and Citrix (ica) on Cisco ASA
Dec 3rd, 2007
Hello !!
I have an Cisco ASA 5505 running ASA OS version 8.2 The problem is when I log on to ASA and when I try to open JAVA RDP terminal server Client less SSL, than the JAVA screen loads but it is small size, it is not possible to resize at all, so I am not able to use it at all.
I tryed to define the link like below :
10.48.24.3/?geometry=1024x786&bpp=16
and only
10.48.24.3
But the same problem :(
also I can`t get Citrix JAVA ICA applet working either, I did exact as Cisco described in the DO IT SELF .doc file, but no way. I think it must be a bug, I can`t belive that I did it wrong. The link for Citrix I used is below :
10.48.24.5/?DesiredColor=4&DesiredHRes=1024&DesiredVRes=768
But it will not work.
Please is there someone who got the RDP and CITRIX Java applet working on the ASA ??
Thank You !!
Best regards
Overall Rating: 5 (1 ratings)
Jason Gervia Mon, 12/03/2007 - 14:12
the gemoetry commands you are using at the end of the RDP URL appear to be correct - though I'm not sure about the "bpp" you have at the end.
You may want to try uninstalling and re-installing the rdp plugin and verify that you are using the bookmark list that you are modifying.
--Jason
050878james Mon, 12/03/2007 - 14:20
Hello !!
Thank You for reply !!
I really tried everything with RDP, but no way, it is the same whole time.
BUT I just got Citrix ICA (Jica), it is working just fine now. Cisco have described wrong in the DO IT SELF .doc file.
So the RDP is still the same :( must be a bug, the Java windows is still small.
jkeeffe Wed, 12/05/2007 - 10:12
How was the DO IT SELF.doc incorrect? Would you be able to post the changes you did to get it to work? - THanks
050878james Wed, 12/05/2007 - 10:30
Sorry, I should post it right after I fixed it, but I was to busy with RDP problems, and I still have not found solution for it.
But back to Citrix Jica. This is what Cisco said in the DO IT SELF .doc file :
How to deploy the Citrix Plug-in
1. Download the citrix java client from Citrix site
http://www.citrix.com/English/SS/downloads/details.asp?dID=2755&downloadID=20731&pID=186
2. Extract the JICA-configN.jar and JICA-coreN.jar files , and then add them to the Cisco ica-plugin.zip archive file using WinZip
3.Import the ica-plugin.zip into the ASA using ASDM or CLI
i.e. #import webvpn plug-in protocol ica tftp://server/ica-plugin.zip
4. Establish a SSL VPN Clientless session and enter the bookmark/url for the citrix server:
Note: It's recommended that you use url parameters to make for more optimal viewing/resolution.
ica://10.56.1.114/?DesiredColor=4&DesiredHRes=1024&DesiredVRes=768
5. Refer to the citrix admin guide for further instructions and parameters:
Link to the citrix admin guide http://support.citrix.com/servlet/KbServlet/download/6284-102-12977/ICAJava.pdf
6. Please refer to your Citrix EULA to ensure it grants you the rights and permissions to deploy the client on your web servers.
______________________________________________
But when I did it step by step as Cisco described, it did not worked at all.
So below is what I did and it work just fine now.
Please in order to make Jica working do following step by step:
1. download the Jica (ICA-Java) Components from Citrix web site:
http://www.citrix.com/English/SS/downloads/details.asp?dID=2755&downloadID=20731&pID=186#top
2. download Citrix ICA-Plug-In from Cisco
ASA software page:
http://www.cisco.com/cgi-bin/tablebuild.pl/asa
3. when both of these archives are downloaded than do following
unpack the .zip archive named JICAComponents.zip extract following files from this archive:
- cryptojN.jar
- JICA-audioN.jar
- JICA-browseN.jar
- JICA-cdmN.jar
- JICA-clipboardN.jar
- JICA-configN.jar
- JICA-coreN.jar
- JICA-Printer.jar
- JICA-SeamlessN.jar
- JICA-sicaN.jar
- JICA-zlcN.jar
- JICAEngN.jar
- sslN.jar
4. now when these files are extracted in one folder, than open the archive named ica-plugin.zip and add all these files named above on to this ica-plugin.zip file.
5. when this is done, than upload this ica-plugin.zip on to Cisco ASA and add it as ICA Plug-IN on the Cisco ASA.
6. Than create the ICA link on the PORTAL BOOKMARK Template as following:
7. Now we can test it and the Citrix will be loaded trough Clientless SSL.
050878james Wed, 12/05/2007 - 10:34
So as you see we need to add the rest of the Jica components or otherwise the Citrix will not be able to load it self.
The file JICA-SeamlessN.jar is the most important, without this you will not be able to load the published desktop or application.
Best regards
alain.kientz Wed, 01/30/2008 - 10:03
I followed the detailed explanation above.
When I double click bookmark, it comes to the point where is shows "Checking credentials" and then it fails with the error "sun.misc.ServiceConfigurationError".
Any idea?
alain.kientz Tue, 02/19/2008 - 06:46
hello,
It worked correctly after I upgraded the Java runtime to the latest version (1.6.0).
Regarding the RDP plugin problem, there is a new RDP plugin available on Cisco download site since a couple of days that corrects the problem.
050878james Tue, 02/19/2008 - 07:00
Thank You for reply, i have just installed it and tested. Now I like the way they did it full screen support too NICE !
But now I noticed one problem with Citrix JICA plug-IN. It work, but allways when you access it FIRST time when java tries to LOAD in it hangs, on that orange color java window, than when I use HOME button on ASA vpn and clicks again on the Citrix URL than java loads as it should.
I hope that Cisco will speak to Citrix about it...
Thank you again !!
Best regards
