Please create RSA keys to enable SSH.
Answered Question
Dec 3rd, 2007
I have a Cisco 1811W running 12.4(6)T2 (c181x-advipservicesk9-mz.124-6.T2.bin), and I'm wanting to turn off telnet access to it and turn on SSH which I usually do on all the routers I manage, but on this particular router when I put in the config command:
ip ssh version 1
I get the error message:
OK, I could have sworn that I had already done that, oh well... so I put in the command:
crypto key generate rsa
specify a 512 bit modulus, the router responds with
% Generating 512 bit RSA keys, keys will be non-exportable...[OK]
But then, when I go back to
ip ssh version 1
I *STILL* get the error "Please create RSA keys to enable SSH"
Any ideas? All I've ever done on a router to enable SSH is "crypto key generate rsa" ...I don't know why this particular router is complaining.
Correct Answer by Joe Clarke about 9 years 6 months ago
Check your config to see if you've defined a specific keypair for SSH. If you have, you will either need to remove it, or generate RSA keys for that keypair name:
crypto key generate rsa label KEYPAIR
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Mon, 12/03/2007 - 14:45
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
thomasdzubin Tue, 12/04/2007 - 07:33
Thanks... that was exactly the problem.
I missed a "ip ssh rsa keypair-name SSHtelnet" in my config so once I removed it, zeroized everything and regenerated the keys it all works! Thanks.
