paolo bevilacqua Mon, 12/03/2007 - 15:30
  • Hall of Fame,
    Founding Member
No, it's not possible. The 877 will connect to a dslam only. If you want to use DSL back-to-back, use 876.
Martin Schoenbacher Tue, 12/04/2007 - 05:19
AFAIK the 876 is also for ADSL (Annex B) and therefore a DSLAM is also necessary -> for a Back-2-Back Connection you have to use the 878 which is SHDSL, with that you can make this connections (i've used it so).
paolo bevilacqua Tue, 12/04/2007 - 07:42
  • Hall of Fame,
    Founding Member
Indeed I meant to say 878, thanks for the correction!
